ClearPass Fingerprinting - Multiple devices same DHCP options
I am working with a healthcare institute that has patient monitors that are being fingerprinted as Computer/Windows/Windows Vista/7/8. These devices are fingerprinted via DHCP helper pointed to ClearPass, and I reviewed the DHCP options, and they are identical to that of true Windows computers.
My question is - How do I change their fingerprint, so that new monitors will also be fingerprinted correctly with a custom fingerprint we've created? I also need to make sure I don't affect the real Windows computers that are being fingerprinted accurately.
Thanks.
Michael Haring
If my answer is helpful, a Kudos is always appreciated!
Re: ClearPass Fingerprinting - Multiple devices same DHCP options
Do they run embedded Windows?
Tim Cappalli | Aruba Security
I'm actually not sure their underlying OS, but we were hoping to tag them in ClearPass as Device Category = Medical, Type = Patient Montior, OS = This could maybe be Windows?
Michael Haring
