ClearPass Guest How-to Guides for Skins
I have found several references to how-to guides for customizing ClearPass Guest skins, but none of the links I have found work for me:
https://arubapedia.arubanetworks.com/arubapedia/index.php/How-to:_Galleria_Skin
https://afp.arubanetworks.com/afp/index.php/How-to:_Galleria_Skin
https://afp.arubanetworks.com/afp/index.php/How-To:_Custom_Skin_ClearPass_Guest
Can someone point me to these documents, please?
Thank you,
David Johnson
Re: ClearPass Guest How-to Guides for Skins
Please contact your Aruba Partner.
Tim Cappalli | Aruba Security
