Frequent Contributor I
ClearPass Guest Phone Call Receipt
We are using the API integration with Twilio to send SMS receipts for our ClearPass guest registration page. It recently came to our attention that India classifies all SMS messages entering the country as "Promotional", which will get blocked if the mobile phone is on the "Do Not Call" registry. I know Twilio has an API to make SIP calls. Does ClearPass support the ability to send the guest account password via phone call?
Re: ClearPass Guest Phone Call Receipt
We can initiate a voice call in policy but not on the guest side unfortunately.
Tim Cappalli | Aruba Security
@timcappalli | | ACMX #367 / ACCX #480
I thought as much, but figured I'd ask. Thanks Tim.
