I am trying to get SMS delivery to work through our company's internal SMTP to SMS gateway using ClearPass Guest 6.0.2.23328
Our SMTP to SMS gateway uses the following syntax for sending messages: SMS/NUMBER@smsgate.ourdomain.de
Since I couldn't get anything to work I set up a monitoring session on the SMS gateway's LAN port using Wireshark.
It seems ClearPass Guest is not sending any data using the SMTP protocol even though the application log says it does:
Client: 172.20.100.30:56845
App User: netadmin
Script: /guest/sms_processors.php
Function: NwaSmsSendMessage
Arguments: array (
'rtn' => array (
'error' => 0,
'message' => 'Message sent',
'args' => array (
'_ajax_mode' => 'submit',
'title' => 'Send SMS',
'handler' => 10,
'hide_processor' => true,
'do_cancel' => '1',
'no_handler' => 'No gateways exist: <span class="nwaIconLink" style="display: inline-block;" title="Create new SMS gateway"><a href="sms_processor_edit.php"><img src="images/icon-sms22.png" style="vertical-align: middle;" alt="" align="absmiddle" border="0" height="22" width="22"></a> <a href="sms_processor_edit.php">Create new SMS gateway</a></span>',
'message' => 'test10',
'recipient' => '+491715552255',
'carrier' => NULL,
I have specified a custom SMTP to SMS carrier for our SMS gateway using the term "SMS/" as its "country code".
I am at a loss here... any help is appreciated!
Thanks!
