ClearPass Guest SOAP interface
I'm trying to use the ClearPass SOAP interface but am running into a few issues.
I am coding in VB.NET and have imported the Service Referance from my ClearPass Guest as https://10.21.4.4/guest/soap_guestmanager.php?wsdl
I am able to use the Referance in my VB project and followed the guide to setting up a basic command.  Using Ping as an example i am getting an error complaining about "GET" used instead of "POST".
Does anyone have any ideas?
VB Code
  Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Dim client AsGuestManagerWebServiceClient = NewGuestManagerWebServiceClient
        client.ClientCredentials.UserName.UserName = "CaptivePortal"
        client.ClientCredentials.UserName.Password = "xxx"
        Dim PingRequest As New EmptyType()
        Dim PingResponse As New ResultType()
        ServicePointManager.ServerCertificateValidationCallback = New RemoteCertificateValidationCallback(AddressOf CertificateValidationCallBack)
        PingResponse = client.Ping(PingRequest)
        MsgBox(PingResponse.error)
    EndSub
    Function CertificateValidationCallBack( _
ByVal sender AsObject, _
ByVal certificate As X509Certificate, _
ByVal chain As X509Chain, _
ByVal sslPolicyErrors As SslPolicyErrors _
) AsBoolean
        ReturnTrue
    EndFunction
App.Config
<?xml version="1.0" encoding="utf-8" ?>
<configuration>
    <startup>
        <supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.5" />
    </startup>
    <system.serviceModel>
        <bindings>
            <basicHttpBinding>
              <binding name="GuestManagerSoapBinding" closeTimeout="00:01:00"
                       openTimeout="00:01:00" receiveTimeout="00:10:00"
                       sendTimeout="00:01:00"
                       allowCookies="false" bypassProxyOnLocal="false"
                       hostNameComparisonMode="StrongWildcard"
                       maxBufferSize="65536" maxBufferPoolSize="534288"
                       messageEncoding="Text" textEncoding="utf-8"
                       transferMode="Buffered"
                       useDefaultWebProxy="true">
                <security mode="TransportCredentialOnly">
                  <transport clientCredentialType="Basic"
                             proxyCredentialType="Basic"
                             realm="" />
                  <message clientCredentialType="UserName" algorithmSuite="Default" />
                </security>
              </binding>
                <binding name="GuestManagerSoapBinding1" />
            </basicHttpBinding>
        </bindings>
        <client>
            <endpoint address="http://10.21.4.4/guest/soap_service.php"
                binding="basicHttpBinding" bindingConfiguration="GuestManagerSoapBinding"
                contract="GuestManager.GuestManagerWebService" name="GuestManagerWebServicePort" />
        </client>
    </system.serviceModel>
</configuration>
Error on ClearPass Guest is:
Invalid SOAP request: HTTP method 'GET' is not POST
Client:    10.21.7.182:51038
Script:    /guest/soap_service.php
Function:  NwaSoapServiceMain
Arguments: array (
  'soap_action' => 'amigopod.guest.ping',
Details:   array (
  'headers' => array (
    'CONTENT_TYPE' => 'text/xml; charset=utf-8',
    'HTTPS' => 'on',
    'HTTP_ACCEPT_ENCODING' => 'gzip, deflate',
    'HTTP_CONNECTION' => 'Keep-Alive',
    'HTTP_HOST' => '10.21.4.4',
    'HTTP_SOAPACTION' => 'amigopod.guest.ping',
    'HTTP_USER_AGENT' => '',
    'HTTP_VSDEBUGGERCAUSALITYDATA' => 'uIDPo+RJgjmioWlGhettZ7ao/0QAAAAAaKv3ioWXQ0KCdRf4d8032IGcwbYuOQxFuyE8923pqb0ACQAA',
    'PHP_SELF' => '/guest/soap_service.php',
    'QUERY_STRING' => '',
    'REMOTE_ADDR' => '10.21.7.182',
    'REMOTE_PORT' => '51038',
    'REQUEST_METHOD' => 'GET',
    'REQUEST_TIME' => 1383766304,
Thanks!
MVP
Re: ClearPass Guest SOAP interface
Did you ever get this issue fixed Eric?
Koen (ACMX #351 | ACDX #547 | ACCP)
Contributor I
Hi, noticed this post and have a similar problem (?). I just dipping my toes in the water here and my code is not half as fancy as the sample above - I'm using powershell. However, I end up with the same error message "Invalid SOAP request: HTTP method 'GET' is not POST" . If someone can spot my (obvious) mistake, I would really appreciate your input!
/F
$user = "user"
$pass = "password"
$pair = "$($user):$($pass)"
$bytes = [System.Text.Encoding]::ASCII.GetBytes($pair)
$base64 = [System.Convert]::ToBase64String($bytes)
$basicAuthValue = "Basic $base64"
$headers = @{ Authorization = $basicAuthValue }
Invoke-WebRequest "http://server_ip/guest/soap_guestmanager.php" -Headers $headers -ContentType "text/xml" -InFile C:\Temp\xmlin.txt -OutFile c:\Temp\xmlout.txt -Method Post
