Frequent Contributor II
ClearPass Guest: is it possible for an administrator to change the Sponsor Name of a Guest Device
I have run into a couple of situations where as an administrator I have had to register an AppleTV as an AirGroup Device on behalf of the owner.  Of course this means the real owner of the Apple TV is not shown as the device sponsor in ClearPass Guest.
As an administrator do I have the ability to edit the device to change this field?
Cheers
Re: ClearPass Guest: is it possible for an administrator to change the Sponsor Name of a Guest Devic
I think  I understand what you are asking , so you don't want your name as the sponsor name listed in the device list ? correct
Thank you
Victor Fabian
Lead Mobility Architect
Thanks Victor,
That was exactly what I was looking for.
