- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ClearPass Guest system deployment
12-11-2013 05:32 AM - last edited on 12-12-2013 04:24 AM by RuthS
I have already deployed over 802.1 x , I now to deploy the guest system,But I have what time it is not clear;
1.Controller configure authentication type is L3 authentication,
2.I want to Guest SSID to connect visitors will redirect to a page,What kind of authentication type CCPM need to use?
How to configure authorization page?
Thanks!
[Mod note: adjusted subject text]
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Clear Pass Guest system deployment,I have some questions
12-11-2013 05:34 AM
You should use a "service template" to configure the guest network on CPPM. That will simplify creating the services.
Colin Joseph
Aruba Customer Engineering
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-11-2013 05:41 AM
Please read the attached doc, it will guide through the setup.
Victor Fabian
Lead Mobility Architect @WEI
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-11-2013 05:43 AM
I should use a "service template-----Guest Access" ?
2.But I will lead to the page before configuration is redirected to the following page;How to deal with it, or how to temporarily turn off this feature?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-11-2013 05:51 AM
1. Yes
2. The page should be: https://<ip address of cppm>/guest/guest.php
Colin Joseph
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-11-2013 06:18 AM
Thank you very much;
But I see the document set the redirect url inside there is no https:// (CCPM - IP)/guest
The configure of the guide is like this: For example,https://x.x.x.x/web_auth.php;
At the bottom of the screenshots;
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-11-2013 06:20 AM
Yes, if you change the default, that is what it should be, what is in the screenshot. You should be able to click on Test on the Weblogin, to see what URL it should be.
Colin Joseph
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-11-2013 06:39 AM
The picture as you say,But after the last connection Guest SSID, will be redirected to the OnGuard Portal, as shown in figure;
I'll be greatly appreciatived for your answer;
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-11-2013 06:42 AM
Is that what happens when you go to https://<ip address>/guest/cisco_web_auth.php?
Colin Joseph
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-11-2013 06:46 AM
After I connect Guest SSID,Expectations are redirected to a page (https://x.x.x.x/guest/cisco_web_auth.php)
But,But it is redirected to another page(https://x.x.x.x/guest/cisco_web_auth/........php),Has increased a lot uri ;
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
