ClearPass Ingress Event Engine Testing
Ciao,
I'm trying to create a new simple Ingress Events Dictionary without success. I attached my example. I'd like map IP and userID coming from syslog but the event generates is blank.
Re: ClearPass Ingress Event Engine Testing
Did you build a dictionary and map it to the event source?
Tim Cappalli | Aruba Security
Yes I did.
I started with a configuration worked (PAN FW sends threat log and CPPM uses CoA to change authorization). What I did has been:
- Modify the dictionary in order to match a new syslog event;
- Associated  the nre dictionary just created in Configuration--Network-Event Sources
- Generare new syslog event and testing.
For troubleshooting I checked .pcap and igesyslog.log the format of syslog event. It seem ok
I check my matching rule in dictionary with http://grokconstructor.appspot.com/do/match. It seem ok
What I've not able to do is troubleshooting regarding parsing of syslog.
