Occasional Contributor I
ClearPass Insight Replication Failed
i have 2 CPPM setup as publisher and subscriber running 6.3.2.63239 on CP-HW-500 platform
i am able to generate Reports on the Insight master which is also the publisher, but i am unable to replicate the report settings to the subscriber server insight
when i do the replicate settings from the admin tab i get the below error and do not see the reports settings on the subscriber server
2014-08-12 10:29:47.000 Start replication to SUBSCRIBER-SRV
2014-08-12 10:29:47.000 Failed to replicate to SUBSCRIBER-SRV err:HTTPSConnectionPool(host='SUBSCRIBER-SRV', port=443): Max retries exceeded with url: /insight/replicator
2014-08-12 10:29:47.000 Replication to peers completed
both the servers are in the same subnet
Super Contributor II
Re: ClearPass Insight Replication Failed
Are you blocking NTP traffic (UDP 123) between the two devices?
not my knowledge, also they are in the same subnet so they dont go through any firewall and directly communicate with each other.
Is this issue got resolved, if so could someone share how it got resolved ?
Thank you
