Hi Airheads,
i'm trying to install CPPM 6.6.0 Eval Version in Hyper-V on my Notebook according to the Technote. Prerequisites are fulfilled. After creating the VM and adding the second virtual HDD, i start the VM and select "1" to install the Eval Version. When i confirm with "y" i get a kernel panic (see image).
Kernel panic - not syncing: Attempted to kill init!
As the docs say that failure in adding a second HDD before starting the VM leads to a Kernel panic as well, i suspect it may have sth to do with the virtual HDD. However, i have tried a lot regarding the drive - making it dynamic instead of a fixed size, creating it under IDE controller instead SCSI, creating it on my physical C:-Drive instead of my D: Drive where i want it, but all changes only produce a Kernel panic. Any ideas?
