ClearPass Integration with Xirrus AP
Hi All,
Could you please inform us whether this is applicable to integrate Xirrus AP on ClearPass (On-Guard & Guest Access) as the Radius CoA action does not include Xirrus in drop list (refer to attached photo)
Also, in case you can provide me with step by step with all parameters needed for proper confguration keeping in mind that the ClearPass revision is 6.6.4Profiler.jpgLog.jpgdevice.jpgService.jpg
