ClearPass Integration with Xirrus AP
Hi All,
Could you please advice whether this is applicable to integrate Xirrus AP with ClearPass (On-Guard and Guest Access) as we failed to get this integration happened keeping in mind that the ClearPass version is 6.6.4
Please, try to send me step-by step how we can configuer the ClearPass as per the attached pics keeping in mind that tXirrus not exist in the Raduis CoA Action list (refer to attached image)
Re: ClearPass Integration with Xirrus AP
I know newer Xirrus code supports coa. It worked with setting it as Aruba vendor.
Hi, Thanks for your kind reply. Unfortunately not working too keeping in mind that our client insist the authentication to be PAP not CHAP Accordingly, could you please provide me with step-by-step how to configure it from scratch on ClearPass
