Frequent Contributor II
ClearPass Kerberos auth against AD
During review of our 802.1x architecture we found reference to the "Active Directory" type of ClearPass authentication source as using NTLMv2.  One of our requirements was to enable Kerberos instead of NTLMv2.
I've set up Kerberos as an authentication source, but it does not appear to be able to authenticate a user using a test TACACS+ type service policy.  I'm seeing the following error
I'm unsure what the above means.  Does it mean that I've incorrectly configured my Kerberos authentication source, or that it is configured correctly but the AD servers I specified are not responding correctly?
rwin = 0
Re: ClearPass Kerberos auth against AD
TACACS+ uses PAP so you’ll need to use a standard AD auth source.
Tim Cappalli | Aruba Security
Thanks Tim! I think that pretty much answers my question... :)
What services other than TACACS+ does Kerberos authentication not work with?
rwin = 0
It’s dictated by the client authentication method. For example, PEAPv0/EAP-MSCHAPv2 requires NTLM for MSCHAP.
