Contributor I
ClearPass Licensing Limitation
Hi all,
do we have any possibility with the new ClearPass Licensing model to assign licenses for certain authentications?
Use case: A customer had 100 Guest licenses and a 500-VA-appliance. This was migrated to 600 Access licenses. From time to time, the customer has more than 200 guests in the network but needs 400 licenses for the internal authentications.
Any possibility to cut guests after a defined threshold to avoid failing internal authentications?
Anything planned in this direction?
Michael
Re: ClearPass Licensing Limitation
There are no hard caps for Guest or authentications. Also, in ClearPass 6.7, the guest license is gone.
Tim Cappalli | Aruba Security
Regular Contributor II
Hi Michael,
You could look at limiting it on the Guest SSID.
On a Aruba Controller you can set the 'Max Associations' (default is 64).
On a Aruba Instant you can set the 'Max Client threshold' (default is 64)
These are the max clients on the SSID. Note: An Aruba AP can support up to max 255 clients per Radio.
Hope this helps.
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
Contributor I
The max stations does not solve the issue as it is on an AP basis and not on the authetnication (guests) in the overall SSID.
How can we take this as an PER?
I just need to ensure that all internal stations will be authenticated while guests may be rejected if the concurrent license limit is reached.
Please post a request for enhancement here: https://innovate.arubanetworks.com/portal_session/new
There is not currently a way to do what you want to do.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
You do NOT need to do this. ClearPass does not have a hard license cap.
Contributor I
What happens after the license count is reached in R6.7?
In both 6.6 and 6.7, there are no hard caps. You will receive administrative warnings that the license has exceeded but authentication will always continue. Also keep in mind that in 6.7, there is no difference between a guest and regular user.
Frequent Contributor I
Hi Michael,
For 6.7, guest license gone and license user is in pool. Clearpass will count in concurrent and release when it out.
For this, I think you can receive the maximum is 525 access and you must buy 100 access to cover the requirement.
Thank you,
Ratchapas S.
Thailand ^_^
Hi
The customer will get more then 525!
He has an CP-VA500, so that will become 525 AL
Then he has 100 guest, that will become 100 AL
So 625 AL in total, if I am correct.
Cheers, Frank
