ClearPass OnGuard deployment with Dell PowerConnect switches without CoA
Hi
We deploy Aruba ClearPass OnGuard in environment when Dell PowerConnect 55xx series switches. As we checked those switches don't support CoA and we consider other method of client reauthentication. From some documents which I have gone through It is not clear for me what method will be the best. We consider:
- snmp enforcment
- CLi enforcement
- short reath time
- phisical reconnect
- Agent based
Has someone deployed Dell PowerConnect switches with OnGuard and could share experiance ? what would be the best solution ?
Any documentation ?
I will appreciate any help
Best regards
Karol
Re: ClearPass OnGuard deployment with Dell PowerConnect switches without CoA
If your network infrastructure does not support CoA/DM, you can leverage the Agent Bounce feature of the OnGuard Persistent Agent.
Tim Cappalli | Aruba Security
ok, thanks for fast response
I will try this solution
best regards
Karol
