ClearPass OnGuard - switch requirements
Is there a list of supported switches that work with ClearPass OnGuard? Or is there a list of required features that the switch has to support in order to provide full OnGuard functionality?
thanks,
Re: ClearPass OnGuard - switch requirements
The primary requirement when it comes to a switch is dot1x support.  Check your switch model documentation and look for the ability to configure a RADIUS server using aaa and dot1x commands.  Different switches will provide differnt levels of richness when it comes to the dot1x.  E.g. can you pass back just a simple vlan vs. a role name vs. a dynamix ACL etc. etc.
You should check with your local account team for more information.
Frequent Contributor II
We asked for this and basically got the exact information that cisco ISE has listed. We have cisco wired. Do you have OnGuard working in an 802.1x environment. Curious how you handle this on wired including how OnGuard agent is deployed.
Super Contributor II
i'll throw my name against this as well, i'm finding it very hard to work out what to do here.
Just curious what your trying to do on the wired side?
802.1x with 3750's and using the Onguard client to manage a quarantine VLAN.
We are hoping to get dot1x going. Our environment should be interesting as we have some switches that are 10years old. We have some 3750s too. So you went vlan switching as opposed to L3 ACLs?
haven't really decided on the overal solution yet, only just got the dot1x working with the NAP agent on Windows.
As it happens it doesn't look like you can use the onguard agent in an 802.1x installation. only microsoft NAP.
Nice. May I ask if you had to have another server for Microsoft NAP or just the clearpass sever?
scottdoorey,
What are you trying to accomplish that you say you can use OnGuard in a .1x environment? I have multiple customers that have OnGuard installed with .1x and its one of the items you are taught how to use in the partner workshops.
Again I know this is a hot topic for everyone out there and we are hoping to have a document soon for public use on how to use on guard. There are a few examples in the CPPM server you just need to click the help link in the top right corner and search for posture.
Thank You,
Troy
