ClearPass - Profiler or Network Device - SNMP String?
Running ClearPass 6.7.3 and we want to use subnet scanning for device and endpoint discovery. In the profile settings, I configured the networks and the SNMP community strings. In the Network Devices, you can also configure SNMP Read and Write community strings. Which one takes precedence? For example, if the string on the network device was spelled incorrectly, but the one in the subnet scan is correct, would we get any errors or Read issues?
Thanks.
Michael Haring
If my answer is helpful, a Kudos is always appreciated!
