Occasional Contributor I
ClearPass Solution Fit
Hope you are all good and smiling :)
I actually need help identify the solution modules that can offer all of the features mentioned below;
Access Management
  • Software /Hardware Based Solution
  • Complete network access control and confidentiality solution,
  • Policy-based enterprise network access,
  • Network device administration control, Device administration in IPv4 and IPv6 networks with full auditing and reporting capabilities.
  • AAA protocols Supported (supports RADIUS for network access control and TACACS+ for network device access control),
  • Authentication protocols including PAP, MS-CHAP, Extensible Authentication Protocol (EAP)-MD5, Protected EAP (PEAP), EAP-Flexible Authentication via Secure Tunnelling (FAST), EAP-Transport Layer Security (TLS) and PEAP-TLS to support authentication requirements
  • Access policies user groups, device restrictions, time of day restrictions, VLAN assignments and other access requirements
  • Supports a rules-based attribute-driven policy model,
  • Integration with external identity and policy databases,
  • Integration with existing external identity repositories such as Windows Active Directory and LDAP servers,
  • Supports a completely lightweight web-based GUI that must be easy to use. An efficient, incremental replication scheme quickly propagates changes from primary to secondary systems providing centralized control over distributed deployments.
  • Integrated monitoring, reporting, and troubleshooting component that is accessible through the web-based GUI.
  • Management for minimum 2500 Network Users
Please advise what exactly i need.
Re: ClearPass Solution Fit
Please define NAC for your environment. Is that posture/compliance checking?
Also, are you working with an Aruba or partner SE?
Tim Cappalli | Aruba Security
@timcappalli | | ACMX #367 / ACCX #480
Thanks for your reply cappalli
You can consider it a compliance sheet but also need to know what solution best fit against the requirements.
