ClearPass Solution Guide: Wired Policy Enforcement
Team Aruba,
We’re happy to announce an update to the ClearPass Solution Guide for Wired Policy Enforcement. Version 2018-01 adds OnConnect for Comware 7 (added in ClearPass 6.7.1), changes for ClearPass 6.7 and some overall tweaks and updates.
2018-01 Release Notes:
  • Major Updates
    • [CW7] Added ClearPass OnConnect section
    • [CW7] Updated dynamic authorization references to use new H3C templates in 6.7
  • Minor Updates
    • [AOS-S] corrected ordering of some commands
    • [AOS-S] added addr-limit config
    • [AOS-S] added SNMP server trap source
    • [AOS-S] updated DUR section to include standard mode added in 6.7
    • [AOS-S] updated web auth service to use new page name attribute added in 6.7
    • [Cisco] Added note about LAN base image
    • [Cisco] updated web auth service to use new page name attribute added in 6.7
    • [CW7] updated web auth service to use new page name attribute added in 6.7
Updated Document Summary:
  • Wired enforcement options and technologies
  • ArubaOS-Switch configurations:
    • Colorless port: 802.1X, MAC Auth, Captive Portal with local and downloadable user roles
    • OnConnect
    • Per-Port Tunneled-Node (PPTN)
    • Per-User Tunneled-Node (PUTN)
  • Comware 7 configuration:
    • OnConnect
  • Cisco IOS 12.x/15.x (IBNS 1.0) configuration:
    • OnConnect
Document Link (v2017-02): ClearPass_Solution-Guide_Wired-Policy-Enforcement_v2018-01.pdf
Future releases to include:
  • Cisco IOS-XE 'Denali' (16.x) with IBNS 2.0
  • Juniper EX
Enjoy
- Aruba Security Team
Tim Cappalli | Aruba Security
TQ
Occasional Contributor I
Re: ClearPass Solutions Guide: Wired Policy Enforcement
Thank you very much for this guide.
So i can use this guide to use cisco switch and CPPM for wired guest captive portal services?
Cisco switch: Catalyst 3560-CX series (version: 15.2(4)E2)
CPPM: running on VM using trial license (90 days)
Cheers
Tariq
Yes.
Contributor I
Hi, Tim
Great doccument.
Question you tested with the 5510_HI_7.10.R1308.
Is the COA already supported here (5510 HI)?
I really need this.
Aruba ACCX #749, ACDX #793, ACMP, ACEAP | HPE Master AS
contact: thierry.lubbers@axez.nl
Yes, as mentioned in the doc:
This configuration has been tested on the HPE 5130EI, 5130HI and 5510HI.
The minimum versions of  Comware 7 required for this configuration are:
5130_EI_7.10.R3113P02
5130_HI_7.10.R1308
• 5510_HI_7.10.R1308
TQ
In document it says:
"Configuring a self-registration workflow in Guest is outside the scope of the document"
Can I get a link to above so that I can complete rest of configuration?
TQ
Thanks Tim,
I followed this guide for CleasPass:Web Authentication section and configured my test CPPM as such. I configured guest page and Cisco switch.
I am getting below error:
Error Code:
204
Error Category:
Authentication failure
Error Message:
Failed to classify request to service
 Alerts for this Request
RADIUSService Categorization failed
Did you configure the Guest side?
TQ
yes I did, not sure if I have missed something.
I followed link you posted for guest configuration.
