Contributor II
ClearPass TACACS+ Dictionary for Opengear
Hello all,
I've created a custom TACACS+ dictionary that can be imported into ClearPass for administrative login into Opengear. It is attached to this post, but make sure you remove the .txt portion of the filename (this forum apparently does not allow .xml file type uploads).
On Opengear, make sure to enable "Use Remote Groups" under Serial & Network -> Authentication. Then simply point Opengear to ClearPass. Nothing further to set up.
The "groupname" attribute should be passed back to OpenGear from ClearPass and should match a local admin group that is defined on the Opengear under Serial & Network -> Users & Groups.
Enjoy!
Tim Haynie, ACMX #508, ACDX #384, ACCP, CWSP, CWAP, CWDP, CCNP R/S, CCNP Wireless, CCNA Security, CCDA
Occasional Contributor I
Re: ClearPass TACACS+ Dictionary for Opengear
Hi Tim, can you create one for Silver Peak?
Perfect! Just what I needed, worked slick :-D
