Frequent Contributor I
ClearPass administrator with custom privileges
Hi
Would it be possible to create a ClearPass administrator with only read access to access tracker and read/write/delete permissions on the Endpoint Repository?
First part with Access tracker is easy, but is it possible to create granular access under the Configuration section and only allow access to the Endpoint Repository and not anything else?
Regards
Jonas Erlund Hammarbäck
Re: ClearPass administrator with custom privileges
Go to Administration> Users and Privileges> Admin privileges and import the attached file.
Create an admin user and Apply the imported privileges to the user.
EDIT:  Somehow I cannot attach an XML file.  Let me try to get that fixed.  Okay, change the attached filename extention from .txt to .xml before importing.
Thank you!
Works greate.
Regards
Jonas
dbo
Occasional Contributor I
thats cool. Do you have an overview about the
 <AdminTask taskid="[VAR]">
commands?
I just want to allow the service desk to create local users. Would it be like that?
      <AdminTask taskid="con.id.lu">
        <AdminTaskAction type="RWD"/>
      </AdminTask>
for CONfigure -> IDentity -> Local Users?
Thx in advance.
Dennis
Hi dbo
The information you need is now available in ClearPass Policy Manager 6.1 User Guide under section Administration\Custom Admin Privileges beginning on page 236.
Regards
Jonas
dbo
Hi Jonas,
Thx for your fast reply and help.
I just searched the user guide version 6.0...
Dennis
Contributor I
I know this is an old topic but does anyone know why I get the error message in the attached screenshot when logging in using these custom admin privleges? Normal admin account is fine.
ClearPass 6.3.1
Cheers
Chris
Did you create the XML file from scratch or export one of the pre-built roles and then change attributes?
Tim Cappalli | Aruba Security
Contributor I
I used cjoseph's one from the earlier post.
Contributor I
Might try and export one and edit it. Maybe a problem between different clearpass versions.
