Contributor II
ClearPass and AD
I had ClearPass working fine with PEAP and GTC using LDAP as the authentication source. We would like to use MSCHAPv2 and AD, but when I made the 2 following changes, GTC - MSCHAPv2 and changed the source from ldap to AD, I get the following error:
rlm_mschap: FAILED: No NT/LM-Password. Cannot perform authentication.
rlm_mschap: FAILED: MS-CHAP2-Response is incorrect
On the summary screen of the failed session, it has authentication source none. However, when I look under the authentication source for the service, I have the AD source I created selected.
Are there are other changes I need to make changing from GTC and LDAP to MSCHAPv2 and AD?
Bob
Aruba
Re: ClearPass and AD
Is ClearPass joined to the domain?  To do PEAP-MSCHAPv2 authentication, it must be joined.
AMFX | ACCX | ACDX | ACMX
Contributor II
It is part of the domain. Also, from the Authentication -> Sources -> and my AD source, I can click on the seach base dn and that works fine, so I think the DN information is correct.
Bob
Aruba
Is this a single domain or multi domain?   What is the message on the Alerts tab of Access Tracker?  Can you post an export of the Access Tracker event?
Contributor II
Re: Clearness and AD
It's just one single domain.
I uploaded the summary and alerts screen from the failed attempt. On the summary screen I'm not sure why it has none listed for Authentication Sources, when LDAP worked it had LDAP listed and when I look at the service, AD is listed as the authentication source.
Bob
Okay.  Make sure the bind user that you used for the AD source works.  That is all I can see now.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Contributor II
I have all the Bind information in there, and from the Authentication Sources -> The AD source -> primary tab, I can click on Search Base BN and can search it. Is that all I need to do to verify the Bind information is correct, or is there another verification test?
Bob
Aruba
In your AD Identity Source, do you have the check box for "Allow bind using user password".   This will attempt a bind using the logon attempt username/password, not the bind user.   Try unchecking it.
Contributor II
I tried unckecking that box and it still fails. I'm working with our SE right now, but he is not sure what LDAP works but not AD. One odd thing I noticed, is even thought I'm using AD. I get ldap errors on the log for my session in access tracker.
rlm_ldap
rlm_ldap: (re)connection attempt failed
Is that normal?
Also, I tried to LDAP and MSCHAPv2, but that was also failing, should I be able to use LDAP with MSCHAPv2? From the users guide it looks like that should be possible.
Policy Manager can perform MSCHAPv2 and PAP/GTC authentication against any LDAP-compliant directory (for example, Novell eDirectory, OpenLDAP, or Sun Directory Server).
Bob
Trusted Contributor I
Can you try testing AD authentication via the CLI?
[appadmin@clearpass]# ad auth -u <username> -n <domain NETBIOS name>
password:
Should result in:
INFO -  NT_STATUS_OK: Success (0x0)
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
