ClearPass and Active Directory
Hi guys,
In ClearPass we can add AD as Authentication Source (Configuration > Authentication > Sources) and joining the AD domain (Administration > Server Manager > Server Configuration > Join AD Domain).
What is the difference between both? Can we join the AD domain without adding the AD as Authentication Source? What is the use of each part?
Julián
Re: ClearPass and Active Directory
Domain join is required for legacy EAP methods like PEAP to validate the password. The auth source is used to derive the SID, for authorization functions and for non-EAP authentication.
Tim Cappalli | Aruba Security
Yes, for EAP-TLS ClearPass doesn't need to join the AD domain. Then when dealing with PEAP, can we join the AD domain without adding the AD as auth source?
Julián
RE: EAP-TLs, correct
RE: PEAP, you need both
Ok, many thanks!
Julián
