I have this integration set up and working, checking for jailbroken devices, check in time, etc.
Here's the issue - the requirement to access the corp network is to both be enrolled in Airwatch + OnBoard. You must first install AirWatch then OnBoard (this is how they want the policy). The problem is that CPPM only syncs occasionally to Airwatch. If we set the sync time to anything less that 60 minutes in the cluster wide parameters, the sync fails.
So the user gets stuck in a state of having enrolled in Airwatch and try to connect to the SSID in order to OnBoard, but since CPPM doesn't have the Airwatch attributes yet, they must wait for a sync to occur.
How are others dealing with this?
