ClearPass and Facebook WiFi
There is a doc about using ClearPass and Facebook WiFi ? (Like for IAP...)
ACMP 6.4 / ACMX #107 / ACCP 6.5
Re: ClearPass and Facebook WiFi
https://ase.arubanetworks.com/solutions/id/81
Tim Cappalli | Aruba Security
Facebook WiFi (and no only Facebook, it is differente !)
https://www.facebook.com/business/a/facebook-wifi/businessowner
Facebook WiFi is available in the CPG social providers...
Yes...
but on Facebook WiFi, only talk about create Facebook Page... (and no Apps...)
Not sure I'm following you sorry.
You would select Facebook WiFi and then "automatically redirect the guest to this provider".
Need a Client ID and Secret ID (and on Facebook WiFi "Page", there is no this information...)
Need to create a Facebook Apps ?
Trusted Contributor I
i just followed the links and for IAP the info is here:
http://www.arubanetworks.com/assets/so/SO_FacebookWiFi.pdf
for clearpass things become more complicated as you indeed have to create a facebook api account and all that.
how is explained here:
http://community.arubanetworks.com/t5/Aruba-Solution-Exchange/ClearPass-Guest-Social-Logins/ta-p/218131
I known the 2 documentation...
but on ClearPass, there is a option for Facebook Wifi (like for IAP...) but no documentation...
Sorry I have to ask, but are you an Aruba customer or partner? You need to obtain a Gateway ID (Client ID) and Gateway Secret (Client Secret) from Aruba. How you go about getting that info depends upon your status.
