- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ClearPass and HP UWW [dot1x / MAC Auth / Guest Captive Portal]
11-05-2015 11:49 AM
- 802.1X
- MAC Authentication
- Guest Captive Portal
Best Regards
-d
ClearPass Product Manager
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: ClearPass and HP UWW [dot1x / MAC Auth / Guest Captive Portal]
11-18-2015 11:27 AM
Hello guys,
Can someone confirm that a command is missing on the "Guest Access with MAC Caching" part in the "Configure WLAN ESS" commands. On my tests in the customer site we could not get an IP address until we added the command "mac-authentication guest-vlan 50". Without this command, after the ClearPass sends the reject for the MAC auth, the user does not get an IP address.
I am not familiar with HP UWW but it's not clear to me that the proposed configuration on this document allows the user to connect to VLAN 50 in case of mac auth failure (before the user authenticates to the guest portal).
Thank you,
Leonardo Mezzanotti
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
11-23-2015 10:41 AM
Adding to my last comment above, we could take out "mac-authentication guest-vlan 50" command by configuring ClearPass to allow any MAC to authenticate. What is correct approach of this Tech Note? In both cases ("mac-authentication guest-vlan 50" or ClearPass allowing any MAC) the Tech Note needs corrections.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
04-19-2017 05:41 AM
I cant download the document, when I press the link it takes me to the support page home.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
04-19-2017 06:00 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
04-19-2017 06:03 AM
Thanx
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
