Trusted Contributor I
ClearPass and certificates
i am wondering if the ClearPass can act a certificate authority, not sure if that is the correct name, I mean is there a way to have to ClearPass generate certificates for clients and check these? or is this a task for a other application such as Microsoft AD?
i only found a way to upload a server certificate which is to validate the ClearPass to the radius / web auth clients i assume?
Re: ClearPass and certificates
ClearPass Guest (Formerly Amigopod) can act as a CA. ClearPass Policy Manager cannot
thank you, that is clear. currently ClearPass Guest (Formerly Amigopod) is a different virtual appliance right? or can I just add another license key on the ClearPass Policy Manager?
correct, they are currently separate appliances with separate licenses.
