Moderator
ClearPass and iboss platform Integration TechNote V2
Teams,
Please find enclosed information and details related to ClearPass and the iboss security platform integration. In this updated TechNote read how to setup and configure the ClearPass Policy Manager and the iboss security platform, learn how to send role-based information for authenticated users to the iboss platform such that the iboss can apply a security policy to users based upon ClearPass role.
iboss have changed a number if items in their config, this technote captures those changes.
You  find the document on the support site located here https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=24860
Happy reading – go fill your boots..!!….. comments and feedback/suggestions graciously accepted.
Best Regards
-d
Snr Tech Marketing Engineer - ClearPass
