Regular Contributor I
ClearPass blacklist guest users
I'm seeing an issue on CPPM 6.3.4 where guest users are getting put into the clearpass blacklist upon account expiration. I thought this was only for bandwidth limit and session duration?
We have guest account set for 7 days mac caching and 5 active-session-count limit. No bandwidth or session limits.
Contributor I
Re: ClearPass blacklist guest users
I'm having the same problem. Clients get put in the blacklist for some reason.
Visitors can get a pass for 24 hours using self-registration. After 24 hours they can just register again.
I assume that if I set the action to delete after expiration, it will not put the clients in the blacklist. However I need to keep these accounts in the database for logging purposes. So deleting them is not an option.
Occasional Contributor I
i am having the same problem.  I have users that are getting on the blacklist after account expiration (12hrs.).  I have seen in other posts that the accounts are going to get removed from the blacklist in 34-36 hours.  Has anyone found a solution for this?
