ClearPass disable WiFi when connected via wired and vice versa
Is it possible to disable wireless of a PC when it is connected and successfully authenticated via wired and vice versa using CPPM?
Thanks in advance
Re: ClearPass disable WiFi when connected via wired and vice versa
This is a client function. You can usually enable it in the BIOS or there
are third party apps that can be deployed.
Tim Cappalli | Aruba Security
Moderator
Pretty sure this can be achieved using our Onguard client.
Best Regards
-d
ClearPass Product Manager
Now you can start a script like powershell after a health scan is completed. I'm no powershell expert so I can't help you scripting, but I'm sure it's possible.
