Regular Contributor II
ClearPass guest NAS Vendor setting with a wild card cert
Hi Forum,
I have (on the Aruba controller) a wild card certs to be used for captive portal. What I'm not sure about is what to type under the NAS Vendor setting field. What's there is securelogin.arubanetworks.com and I understand that I should have it match what's in the CN in my cert on the controller.
Any advise is appreciated.
Re: ClearPass guest NAS Vendor setting with a wild card cert
captiveportal-login.<yourwildcarddomain.tld>
Tim Cappalli | Aruba Security
Thank you Tim.
