Contributor I
ClearPass rules combined or split?
I was at recent event and a discussion came up about clearpass deployments.
Some say for better proformance you should combine your clearpass service rules e.g. mac auth/social into one rule, others say you should split them out as it makes it easier to troubleshoot.
What is the community view?
Guest Blogger
Re: ClearPass rules combined or split?
My personal preference is to combine as much as possible in one service. But I make a distinction between wired, wireless and management services.
And I use "dividers" to order the services in a more readable way.
@rene_booches | AMFX #26, ACMX #438, ACCX #725, ACDX #760, CCNP R&S, CEH | Co-owner/Solution Specialist@4IP / blog
There's not a one size fits all answer. Literally every ClearPass deployment is different in some way.
Tim Cappalli | Aruba Security
@timcappalli | | ACMX #367 / ACCX #480
Contributor I
Tim, this is true no clearpass is same, i have deployed multiple CPPMs of varing sizes and none are them same.
It does bring up the point, however there is no clear, best practice guide on deployments.
