Contributor I
ClearPass sends to Cisco ASA dACL RADIUS CoA
Is there a way to send from ClearPass RADIUS_CoA dACL to Cisco ASA VPN ?
For example the OnGuard Agent finished the NAC health checks when the user connected to the VPN,
and I want to send the ClearPass a RADIUS_CoA dACL to Cisco ASA, if the health check result is quarantine or allow all.
Balazs
Balazs
Re: ClearPass sends to Cisco ASA dACL RADIUS CoA
What version of code are you running on the ASA?
Sent from Nine
Tim Cappalli | Aruba Security
Contributor I
Hi Tim,
Cisco Adaptive Security Appliance Software Version 9.3(3)2
Device Manager Version 7.4(3)
Balazs
Balazs
Contributor I
So, if I send a generic Cisco Coa Reauthenticate session or generic Cisco Coa Terminate session nothing happens. I sent a RADIUS:Cisco Cisco-IP-Downloadable-ACL deny ip any any nothing happens.
So, my question is what attributes should to be send by the clearpass to the Cisco ASA in coa message if we want to change a user ACL list after a NAC check.
Balazs
Contributor I
what do you mean to trigger the reauthentication?
Balazs
You need to trigger a reauthentication for the user to get the new dACL.
Contributor I
Bounce or reauth ?
Balazs
CoA. Can you post your enforcement policy?
Contributor I
I send only dACL in CoA:
Balazs
Balazs
