Frequent Contributor I
ClearPass to IAP role mapping
Is there a way to use ClearPass to put different roles into different vlans on IAP?
Re: ClearPass to IAP role mapping
Yes. You can either return the VLAN from ClearPass or add a VLAN assignment to the role in Instant under access control.
Tim
Tim Cappalli | Aruba Security
