Regular Contributor I
ClearPass update problem
This morning, I have done the ClearPass 6.2.0 Cumulative Patch 1 update but now I have no more access to the GUI and the Guest part and don't know if the update is correctly done. I can still access the CLI, so is there a command to know if the update is done or something to go further ?
Dimitri
Re: ClearPass update problem
It does apply a patch to the webserver so first check to see if the services are all running
service status all
Thank You,
Troy
Thank you.
Ok so here is the result of the command :
run
service restart all
It should have shown the services status and it looks like yours are down.
Thank You,
Troy
Problem solved after the restart of all services (and the restart of CP because of the update). Thanks for you quick help Troy.
Dimitri
