MVP
ClearPass - using different role mappings & role id
So I have a need to use 2 different "Guest Roles" role mappings.
I changed the default [guest roles] one to "My Roles1" through the /guest plugin manager. This works fine.
Now however I need another role mapping "My Roles2" which I should be able to use in as the role-id in self-registration portals and other captive portals.
I suppose I need to create my own version of the role-id field for this? What is a bit beyond me is how I can tie my own "My Roles2" role mapping into this. I'm guessing I can't simply use the same options generator in that field?
Has anyone done this before or am I going the wrong way about this?
Koen (ACMX #351 | ACDX #547 | ACCP)
Re: ClearPass - using different role mappings & role id
What are you trying to do?  You can only have one role map per service.  Keep in mind that an authentication can derive to multiple roles.  You should select evaluate all for that to occur.  In that instance, you can then say in the enforcement profile if MyRole1 AND MyRole2 exist, then the intended action.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
MVP
I'm simply trying to have 2 different self-registration portals that use 2 different role mappings.
For example
Self-reg portal 1: captain - lieutenant - cannon fodder
Self-reg portal 2: employee - contractor - guest
Problem is I don't want to show the roles from portal 1 to users from portal 2 and vice versa.
I would need to be able to clearly identify/differentiate users from both portals in the same guest user database.
I am talking about the role mapping used when creating users though, not just the role mapping after authenticating.
See if this thread helps you out :
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Create-new-account-roles-on-ClearPass-Guest/m-p/84170/highlight/true#M864
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Yes...that should help you out (link above).  But...you will need to create two self-reg pages with two services, CP profiles on the controller, two URLs, etc...
In each self-reg page, you will edit the form where the user selects the role and create the list there.  In terms of creating those roles, the thread above will help you
Seth R. Fiermonti
Email: seth@hpe.com
MVP
that is creating more roles within the same role mapping.
I would prefer to be able to use 2 completely different role mappings if possible.
My problem is I have no idea how to point ! selfreg portal to use role mapping 1 where selfreg portal 2 uses role mapping 2.
I can only configure 1 role mapping that will be used by both selfreg portals though /guest > Administration » Plugin Manager > ClearPass Guest Services. So how do I get the role id in selfreg portal 2 to use a different role mapping?
I'm guessing I need to create a secone role id field but here I'm stuck as the default role id doesn't actualty reference a role mapping anywhere.
Once you create the self registration page and you create the role  it should pick it up automatically from the list of available user roles that you defined under the role mapping and enforcement :
Guest1
Guest2
Employee
Contractor
Thank you
Victor Fabian
MVP
It does that for 1 role mapping yes from what you configured in  /guest > Administration » Plugin Manager > ClearPass Guest.
I need it to use another role mapping.
OIr did I misunderstand you?
That's correct.
Its kind of what you do with the controller, you configure and then you decide what role will use based on what you define in the enforcement
Thank you
Victor Fabian
MVP
And that part I get but is not what I want to achieve..
! selfreg portal needs to have another set of roles that the user can subscribe to than the other.
Per default [Guest Roles] is the rolemapping used for this.
This mapping goes as follows:
(GuestUser:[Role ID] EQUALS 1) [Contractor]
(GuestUser:[Role ID] EQUALS 2) [Guest]
(GuestUser:[Role ID] EQUALS 3) [Employee]
So selfreg users can 'choose' one of those 3 roles. The Role ID field will look at  /guest > Administration » Plugin Manager > ClearPass Guest. to know it needs to map the values in the Role ID field with those names.
My idea was to use that role mapping for one service and the mapping below for a different service and keep them completely seperated.
[My Roles] is mapped as follows:
(GuestUser:[Role ID] EQUALS 1) captain
(GuestUser:[Role ID] EQUALS 2) lieutenant
(GuestUser:[Role ID] EQUALS 3) cannon fodder
The problem is that the Role ID field always looks at what is configured in  /guest > Administration » Plugin Manager > ClearPass Guest and I was hoping there was a way to copy the Role ID field and have it points to My Roles rolemapping.
I guess I won't be able to do that and will have to use a single rolemapping which has all 6 roles and then limit the values that can be selected from this rolemapping per service used with the validator arguments or something.
(GuestUser:[Role ID] EQUALS 4) captain
(GuestUser:[Role ID] EQUALS 5) lieutenant
(GuestUser:[Role ID] EQUALS 6) cannon fodder
