Frequent Contributor II
ClearPass wired 802.1x use local vlan on switch?
After reviewing the ClearPass 802.1x wired template, it looks like to implement 802.1x we must assign a vlan to a user once they authenticate.  In most configuration guides, this is called a dACL.  For example (https://community.arubanetworks.com/aruba/attachments/aruba/tkb@tkb/223/1/Cisco%20Switch%20Setup%20with%20CPPM-v1.2.pdf) indicates this behavior under the Section 3 802.1x Service Setup.
I would like to have users authenticate with 802.1x wired, but use the vlans that are already assigned on the port.  Is this possible?
rwin = 0
Re: ClearPass wired 802.1x use local vlan on switch?
Yes, just send back an accept.
Tim Cappalli | Aruba Security
Can you point me to a guide that details how to do that with an enforcement policy?
Is there an option above that I should be sending back specifically?
rwin = 0
Use the pre-built [Allow Access Profile] which just returns an ACCESS-ACCEPT.
Thank you! This worked great.
rwin = 0
