Frequent Contributor I
ClearPass with ADCS - certificate renewal process?
I've setup ClearPass to use ADCS for sigining of Onboard device certificates, but was wondering what the renewal process is?
When re-provisioning devices, does ClearPass just perform the renwal on the clients behalf through ADCS web services? Are there any other gotcha's to be aware of?
Trusted Contributor I
Re: ClearPass with ADCS - certificate renewal process?
it would expect so, pretty much the same as with certificates from ClearPass itself, but never tested this.
someone else might have?
