Occasional Contributor I
ClearPlass and Cylance PROTECT Integration
Hello, has anyone done any integration between ClearPass and Cylance's PROTECT?  I know that PROTECT is an agent that runs on a endpoint, so perhaps OnGuard can determine if the agent is still there.  Also any integration between PROTECT's management and CPPM so that API's could de-authenticate or put end-users in quarantine areas?
Moderator
Re: ClearPlass and Cylance PROTECT Integration
James,
Is this still a requirement for you?
I ask as it's about to hit the street, might be looking for a tester.
Best Regards
-d
ClearPass Product Manager
Word on when this might be hitting the streets again?
