Frequent Contributor II
Clearpass 6.0 Aruba wireless Integration Guide Question
Hello!
I just ran through the integration guide that was created!  Amazing document.  So easy to follow!
I have one snag.  I have everything working up until I create the guest user account and click the login button.
It redirects to securelogin.arubnetworks.com..... and then goes back to Auth Server Timeout Error.
What did I miss?
Thanks!
Re: Clearpass 6.0 Aruba wireless Integration Guide Question
