Contributor I
Clearpass 6.7 Guest - Running into an error with German translation
Hi everyone,
ran into an error in selfregistration when using german translation.
Can anyone point me in a direction where to look for the field indicated in this error message:
Regards Johnny
Re: Clearpass 6.7 Guest - Running into an error with German translation
Problem is with every language. Only English wors fine. I discovered that in other languages Pages -> Forms are broken (screen) and have "zombie" fields. For comparison the "same" form in English.obraz.pngobraz.png
Please contact Aruba TAC to get this validated. I just tried in my lab in Dutch which went without this error. It seems that a specific feature must be enabled to trigger the message.
same here...
Any updates? Could solved by TAC?
Contributor I
I did not follow up with TAC. Hoping for 6.7.1 which is due end of January. I have diasabled translations and stick to English.
