Regular Contributor II
Clearpass 802.1x template unknown_CA
Hi Guys,
I am a little confuse how this works.
I have a controller and ClearPass. Created service Aruba802.1x template and its working with local user database for tests.
Works ok with IOS and Android.
When we get to windows it fails to connect saying on tracker EAP-PEAP - fatal alert by client unknown_ca
 I see that i don't have a CA on windows network. IS it possible to use one in clearpass?
if not waht should i do ? disable certificates on 802.1x?
Sorry , but I am not used to Cpass
Regards
Re: Clearpass 802.1x template unknown_CA
That's likely because it's using the self-signed certificate that comes out
of the box.
Do you have an Aruba partner? There is a bit of planning around certs and
authentication methods that should happen before you deploy.
Tim Cappalli | Aruba Security
I am the installer.
Not the client. We had already installed some with AD and the clients had certificates.
This client does not have the CA on windows server, so for this I am a little confused on planning.
Do I need a CA ? Can't we just not use clearpass certificate?
Regards
Beconnect,
What are you trying to configure?
Is it EAP-PEAP or TLS?
Did you install a server certificate on ClearPass?
Did you also install the CA that issued the certificate in Clearpass's trust list?
Does the Windows client have "Validate Server Certificate Enabled"?
Here's your options:
If you're supporting BYOD devices without Onboard, you'll need to get a publicly signed certificate.
If you're supporting only managed clients (Group Policy or Profile Manager/MDM), then you can use a self-signed certificate.
If you're using Onboarding for ALL users, and doing single SSID onboard, you'll need a publicly signed RADIUS and web certificate.
If you're using Onboarding for ALL user and doing dual SSID onboard, you can use a self-signed or private RADIUS server cert, but you need a public web server certificate.
If you're using Onboarding for some users, and doing single SSID onboard, you'll need a publicly signed RADIUS and web certificate.
If you're using Onboarding for some users, and doing dual SSID onboard, you'll need a publicly signed RADIUS and web certificate.
Hi guys,
Not using onboard.. no licenses for that.
just Clearpass Policy manager.
The only thing that I have done, was do the integration of clearpass with Aruba via Aruba technote v1.3integration ( in attached)
What I see is that , upon the creation of the service , i suppose no certificate was installed.
Should I install one? IS it possible?
BYOD is working ok connected via 802.1x and certificate.. Windows not.
I only configure the template of service on Clearpass and config the controller reading the technote.
Regards
Yes, you should get a publicly signed SSL certificate.
If you are just testing, uncheck "Validate Server Certificate" on your Windows machine.  Otherwise you should get a public certificate for your server and upload the CA from that public certificate to the trusted list.
Guys,
So i should buy a public certificate?
install on windows server and upload to the trust list of Clearpas?  I am not using ldap authentication , why do i need the server certificate?
atached the config of the clearpass service
Sorry for behing so dummy on this
Regards
You would do a CSR on ClearPass. Purchase the SSL certificate and upload it to ClearPass as the RADIUS server certificate. You don't need to do anything on a Windows server.
Take a look at this slide deck: http://community.arubanetworks.com/t5/Americas-Airheads-Conference/Breakout-Real-world-802-1X-Deployment-Challenges/gpm-p/129211
