Clearpass + Aruba Instant + Self-sponsoring
Hello community, I was configuring an scenario with a cluster of Aruba Instant, Clearpass 6.4 and a SSID with Guest Self-Registration and Self-Sponsoring (grace-period of some minutes for looking at the email).
I have seen a guide that describes a similar scenario but the principal difference is that uses a Aruba Controller instead of a Instant cluster. The guide is: http://community.arubanetworks.com/aruba/attachments/aruba/aaa-nac-guest-access-byod/14147/1/How-to%20Self-Register%20and%20Self-Sponsor%20(validated%20email)%20-%20Secdata%201-4.pdf
I can't follow this guide because the options in the controller / Aruba Instant are not similar. There is any other guide with the scenario described?
Thank you very much,
Best Regards.
Frequent Contributor II
Re: Clearpass + Aruba Instant + Self-sponsoring
Do you want them to change VLAN once authenticated or just same vlan?
You can create a guest SSID and use the authentication option external captive portal and add the clearpass guest url there.
I don't really need to use different VLAN.
Yes, I have made a Guest Self-registration and a Guest Self-sponsorship with the Aruba Instant in combination with Clearpasst (using the way you describe, external auth) but the real resultat that I need is:
-- User connects to the guest ssid.
-- Instant AP redirects to the Guest-Self registration page.
-- Clearpass send an email to the address that user typed.
-- User have a role that permit navigation during 10 minutes, grace period for navigate to the webmail and validate the connection (self-sponsorship).
I don't know how to do the grace-period of 10 minutes without using a Aruba Controller (Change of Authority feature).
Thank you,
Best Regards
I am the author of that original guide.  It was written for cppm a few versions back.  Things have changed a bit through the versions and this can be achieved much easier.  Please see this more recent and excellent guide here.  It is based on IAP as well.  Enjoy. :-)
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/HowTo-Auto-Sponsor-with-Clearpass-Guest/m-p/255232/highlight/true#M23974
ACCP, ACCX #817, ACMP, ACMX #294
