Occasional Contributor I
Clearpass CA issue
I configure clearpass as root CA for onboard device provisioning. I install certificate on IOS device but I try to show certificate view by device or username. There're not any records What is my fault?
Thank you
Re: Clearpass CA issue
Screenshot please.
Tim Cappalli | Aruba Security
After user authentication is successful.
It hits BYOD-Provision service and user will get provision role
On controller side, I set rule as captive portal. Page will be redirect to provision device portal. I enter username and password. Authentication is successful. User hit BYOD-Pre  auth service. no any radiusattribute return to user because I used default profile.
The Onboard Pre-Auth service should generally always send an Allow Access. Are you able to get past the Onboard login?
