Occasional Contributor I
Clearpass COA issues on brocade switches.
Hello all,
I'm trying to setup COA on clearpass so after a device gets profiled the port they're on gets bounced and then they get put into the correct vlan. Right now when i try to a manual COA from access tracker it says "Insufficent Paramaters Received"  I've based my COA profile off of another post that i've seen here but no luck.  Also i have the Enable Radius CoA: Checked on the device profile and I have it enabled on the switch.  I'll attach some screenshots
Re: Clearpass COA issues on brocade switches.
I was referencing that to make my Enforcement Profile.  I'm thinking that it has something to do with the NAS-Identifier (32) which is supposed to be the port according to brocade, however on the screenshot it's showing up as the name of the switch... I'm not sure what i'm missing here.  Has anyone set this up on brocades before?
