Clearpass CoA issue with HP
I am having some issues with CoA on a HP E3800.
 I configured the switch to do EAP-radius authentications on port 23 and that works fine. However, when a submit a change status it fails.
CoA port: 3799 on both ClearPass and Hp switch
show run output :
radius-server host 10.0.0.156 key "arubahptest"
aaa accounting commands interim-update radius
aaa authorization commands radius
aaa authentication port-access eap-radius
aaa port-access authenticator 23
aaa port-access authenticator active
Has anyone else ran into a similar issue ?
Re: Clearpass CoA issue with HP
Did you verify that the switch supports it?
Also, most switches require that you enable CoA.
Tim Cappalli | Aruba Security
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Frequent Contributor II
* Make sure the IETF:NAS-IP-Address attribute matches the IP you have defined for the device in CPPM
* Make sure you have selected the correct vendor + enabled CoA in the CPPM device
* Make sure CoA is enabled for the CPPM IP on the switch
For HP ProCurve related 802.1X see this great wiki page at FreeRADIUS wiki: http://wiki.freeradius.org/vendor/HP#RFC-3576-Change-of-Authorisation-&-Disconnect-Message
ACMX#255 | ACDX#742 | ACCX#746 | AMFX#25 | ACMP | ACCP | AWMP
www.securelink.nl
I have checked the following items listed above and still no success. I did check and hp states they support coa. any other gotchas?
HP 3800 supports CoA yes. I have had this working with HP ProCurve 3500/5400/8200 series, but 3800 should be in the same family.
Are you sure have configured CoA (or dynamic-author) correctly on the HP 3800? Can you paste the relevant config?
You can also try and enable accounting on the HP 3800 and see if that changes anything.
Do you see anything in the logging of the HP 3800? ("show log -r")
Also, if all fails, you can check with a packet capture if CPPM is sending the correct request.
www.securelink.nl
This should work , I tested this out with 3800 recently with no issues
Thank you
Victor Fabian
hostname "HP-3800-48G-PoEP-4SFP+"
module 1 type j9574y
module 2 type j9574x
radius-server host 10.0.0.156 dyn-authorization
radius-server key "arubahptest"
ip default-gateway 10.0.0.254
ip route 0.0.0.0 0.0.0.0 10.0.0.254
ip routing
oobm
Does this switch have multiple IP addresses? What is the value of the Radius:IETF:NAS-IP-Address attribute?
Can you post snippets from the request in the access tracker?
www.securelink.nl
