Contributor I
Clearpass Guest Implementation
has anyone installed Clearpass for Guest users? How did you implement it with regards to authenticating users before allowing them access to the network? Where I work I've been asked to set Clearpass so that guests cannot access the network until they are validated in some way. The sponsored email option they don't like!
Re: Clearpass Guest Implementation
I don't think you have a lot of options here.
If you want the guest validated before getting 'full guest access' you're going to need to have someone validate their account.
This can be done either ahead of the visit by having a guest-provisioning operator create the account (often the receptionist) or during the visit with something like sponsor verification.
Or you give everybody in the company guest provisioning rights and an instruction booklet detailing on how to create guest accounts themselves :P
Koen (ACMX #351 | ACDX #547 | ACCP)
Contributor I
Thanks, that's what I thought and had been led to believe.
Thanks for yuor response
