Contributor II
Clearpass Guest Role Mapping Issues
For some reason Guest role mapping is not working on our production CP server, but works on our test server.
1. Created role "Campus Device"
2. Added to the role [Guest Roles] Role mapping policy.
3. Created a device in CPG with the Role "Campus Device"
4. Have an  enforcement policy that only allows access if the device has the tips role of "Campus Device".
Again it works fine on our test server, but not our production server.
I've done a screen by screen comparison of the Service, Role Mapping, and Enforcement Policies between the Production and Test Servers and can't find a difference.
Thanks.
-Neil
Neil Johnson
Re: Clearpass Guest Role Mapping Issues
Are you using the Guest Device Repository as an Authorization Source?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Contributor II
Yes.
Neil Johnson
Do you have the Role ID to TIPS role mapping configured in the role map that is configured in the service?
Tim Cappalli | Aruba Security
Contributor II
Yes, I'm using the same Role mapping policy "[Guest Roles]".
-Neil
Neil Johnson
Please export an access tracker log for one of the requests and post here.
Contributor II
Here you go!
Neil Johnson
Contributor II
Just spent an hour on the phone with our promoted SE.
Turns out that you should NOT use the Default [Guest Roles] Mapping in Service rules, but create a new, separate Role Mapping (at least that fixed it for us).
-Neil
Neil Johnson
