Contributor I
Clearpass Guest and Newhotel PMS integration.
Hi all.
I have a costumer who has installed in the hotels Newhotel PMS software, and they asking us about the possibilities to integrate, newhotel PMS with ClearPass Guest, especially in SMS services.
http://www.newhotel.com/es/Global/SoftwareNewhotel.aspx
Could you help me please.
Somebody integrate ClearPass Guest or Amigo-Pod with Newhotel solutions?
Thanks in advance for your help.
Regards
Senior Pre Sales Enginner
Arrow ECS Spain.
ACMA, ACMP, ACCP, ACDX #325
Re: Clearpass Guest and Newhotel PMS integration.
What are they exactly looking for? What are you trying to accomplish with the SMS?
I looked on their site, but they dont give you any technical specs on the products or any intergration guides, and today we dont have any intergration guides.
Hopefully another customer has worked with them before and will chime in and give you some pointers.
Thank You,
Troy
