Moderator
Clearpass Guest networking info
Hi
Very simple question, just to clear up my head. When using Clearpass Guest, if I don't enable the secondary interface, I will never be able to see the captive portal, will I?
Or, let's put it differently, If I http/s the management interface (redirected or not) I will always receive the mgmt WebUI, regardless if the data interface is enabled or not. Am I right?
Samuel Pérez
ACMP, ACCP, ACDX#100
If I answerd your question, please click on "Accept as Solution".
If you find this post useful, give me kudos for it ;)
Regular Contributor I
Re: Clearpass Guest networking info
I believe it still depends on the URL which you go to: https://<ip_of_CPPM>/tips will bring up he management portal.
I believe I have deployed clearpass for a customer with only the MGMT interface enabled, and they are able to get to the regular web portal.
ACDX, ACCP, CISSP, CWNA
samuel.perez wrote:
Hi
The management interface is mandatory and can do everything if it is the only interface configured.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
